Subject: Re: Red cloud coming thru grey paint
7/31/19
Scott B.
Walked into a laundry room with a plywood top and end panel enclosing a washer and dryer. It appears that a 1/2" insulation sat on top of dryer below the plywood top.Everything painted grey 6 months ago, now on surface a red haze is forming across top even over washer area. You can wipe off the red haze after a bit of rubbing and the grey reappears on the surface,.....really it never left. Sorry not sure what paint finish is ---any idea whats happening??
7/31/19       #2: Red cloud coming thru grey paint ...
So it's not your work, you're just curious? The only guess I have is that it was over-catalyzed tinted cv. But if it's not your work, why worry?
7/31/19       #3: Red cloud coming thru grey paint ...
Scott B.
As usual a friend of a friend asking and yes I'm very curious. Finished by a painter so not sure he would of used a catalyzed product. The finish feels sound, its just this red haze appearing from nowhere just sitting on the surface.
8/1/19       #4: Red cloud coming thru grey paint ...
Have the friend of the friend ask the painter. A lot easier than me guessing what happened and you guessing what he probably didn't or can't use.
8/26/19       #5: Red cloud coming thru grey paint ...
Matt Meadows
Rich is correct, that is a symptom of over-catalyzation but that doesn't make it a sure bet.
If the haze feels sorta greasy and has a slight "cat piss odor" then that further validates the idea of over-catalyzation.
There are some bozos in this industry that think that catalyzed finishes are like Bondo, in that "adding more catalyst" makes it harden quicker or mystically makes it more durable. I could easily imagine someone doing this specifically on a C-top.
8/26/19       #6: Red cloud coming thru grey paint ...
scott
Thanks for the responses, I suggested that they have the painter sand, prime
and finish, but she decided to
have a corian top put over it. I will give it the sniff test when i go back to check on over catalyst.
