Subject: Re: Painting CV on Cast Acrylic
9/2/19
Matt
An upcoming job includes some components made from cast acrylic to be painted a custom color (decorative HVAC register grilles with a specific pattern laser cut on them).
The material will be 1/4" cast acrylic. I am spraying samples now to test.
Has anyone done this? The product will likely be 2 fairly thin coats of opaque followed by 1 clearcoat, which is basically our normal process for wood.... just sprayed in thinner mils.
9/2/19       #2: Painting CV on Cast Acrylic ...
We painted a small batch of acrylic a while back and the distributor we got the acrylic from said to use a primer that was alcohol based rather than typical solvent. That left us with BIN as it was a quickie job. They said many of the conventional solvent based primers/topcoats would not play well with the acrylic (lacquer thinner, toluene, etc). This was a top painted item. Not sure what someone would do for back painted but perhaps WB?
9/2/19       #3: Painting CV on Cast Acrylic ...
Matt
Thanks for the reply Mark, I'll keep the WB option in mind.
I tossed my samples into today's flavor of white being sprayed. After 1 coat and a 1 hour cure, they look quite good.
We'll let them cure up a few more days and do some scratch/adhesion tests just to see what happens, maybe freeze them and see if temp swings cause any issues.
9/2/19       #4: Painting CV on Cast Acrylic ...
I would add in any sort of cleaning you think they may see. Im sure you know that many types of acrylics depending on edge treatment will freak out with things like ammonia etc.... We didnt do any edge treatment. Just machined and sprayed. I wasnt as wise as you to do some torture testing but I also made it clear to the customer that all I could do was advise and we werent standing behind the finish treatment they wanted (paint).
If you have to stand behind the substrate and finish your wise to do all the torture testing you can.
9/2/19       #5: Painting CV on Cast Acrylic ...
Make sure you heat cycle your samples. Acrylic moves a lot and depending on the HVAC system, the heat cycles may expand the acrylic quite a bit. I'd suggest finish failure would be during the first heating season.
