Subject: Re: Grain Filling stained wood
10/29/19
Pascal Member
Hello everyone
I Have been lurking in the forum for a while but could not quite find a definitive answer to my question. The simplest way would be to first explain my finishing routine :
1-Sand wood Up to 120 grit
2-Grain fill with diluted black timbermate
3- Sand with 150 gritt
4-Painfully repeat step 2 & 3 three times
5-Spray diluted black dye to about 25-30% of planed "blackness" (mohawk/behlen Brand)
6- Spray a washcoat of Precat (6% Solid)(Mohawk/bhelen Duracoat
7- Apply black wiping stain (mohawk/behlen) since the dye doesn't color the pores of the wood
8-May Apply a few coats of black toner if still too light (Precat thinned to 5% solid)
9- Build about 3 coats of 10-12% solid precat (my gun doesn't give good result with more solid).
10- If build is enough REALY LIGHT wet sanding with 600 gritt until smooth to the touche
11- Finish with one 6-8% precat coat (or repeat 9-10 depending on the look/feel to touch)
I came with this routine after many samples on scrap and it has given me great results (although not Always consistently but I suspect I am the cause rather than the finishing routine)
My question concerns the grain filling steps. From what I have read, people generaly seal before grain filling. My concern is that I need to sand VERY AGRESSIVELY to remove the excess timbermate wich means that stain/dye/sealer before grian filling is almost useless since I will sand through all those layers in no time.
I Have read that some people seal before so it makes the sanding easier and prevent the filler from staining the wood but will the dye be able to color the wood after the sealer. Maybe If I Apply a 5% washcoat than grain fill and sand aggresively that washcoat will be gone and I would be able to dye/stain with no problem. The wascoat would help sanding the filler but would be removed after sanding.
Overall I'm lost on this. If the best way is to continue to Apply the filler to bare wood I will do it but sanding the excess is PAINTFULLY long and can takes hours/days.
10/29/19       #2: Grain Filling stained wood ...
mike j
Are you trying to get a full filled black finish? You could tint the grain filler with 844 black tint. You could also blacken (ebonize) the wood, after applying the black wood filler, using black ink. I would then seal with polyester and top coat. If you are finishing in full filled black why not use a closed grain wood or MDF?
10/30/19       #3: Grain Filling stained wood ...
pascal stgelais
Thanks for your response but my question was regarding whether applying a wqscoat before the grain filler would help sanding it. will it also cause troubles when staining since the filler will be sanded very aggressively thus removing most of that wascoat
10/30/19       #4: Grain Filling stained wood ...
Do you know how to use a cabinetmaker's card scraper? Way faster with filler than sanding, and less chance of going too deep.
11/18/19       #5: Grain Filling stained wood ...
rick morehou Member
rich c....i love your response. also, to those who are unfamiliar with card scrapers, take time to learn more about these very valuable weapons for the finisher.
i enjoy making them almost as much as using these tools, the uses expand as you use them more. since i cannot say enough i will stop here and possibly post an article on these tools.
thanks again rich c you let the cat out of the bag here.... thanks for reading rick m
