Subject: Re: Crack repair
Crack repair
12/7/19
Hazeltree Member
So in final assembly of a large cabinet I basically applied to much force and caused a small crack in my end panel. This panel is soft maple finished with kemvar plus conversion varnish. The crack is tight and I haven’t had any luck with a conventional filler stick. I was hoping someone may have a good idea for me on how to repair this finish. I have included a picture for reference.
12/7/19       #2: Crack repair ...
That looks like a tough one. Like you cracked the profile edge off the sticking. Personally I cant imagine any finish repair lasting in that area other than to re-make it. Its a bummer but likely the time you will have invested in multiple failed attempts at repair may just make it easier to re-make.
One of those "just rip the bandaid off" situations.
12/7/19       #3: Crack repair ...
Jonathan Mahnken
spread the crack. pack it with yellow glue, clamp and dry.mask off door where it joins with the rail. sand, spray the crack only,dry,sand, spray entire stile, remove masking immediately while still wet, hope for the best.
12/7/19       #4: Crack repair ...
I second Johnathon's suggestion.
12/7/19       #5: Crack repair ...
Put a shop vac hose on the back side, put glue on the front side. It will pull the glue all the way through. Then put on protective strips and the sides and clamp.
12/9/19       #6: Crack repair ...
Hazeltree Member
I was able to glue it and screw it from the back side. Seemed to tighten the crack and hold it really well. Resprayed it last night and it looks good as new. We’ll see how it does long term. Thank you guys so much. I really appreciate it.
12/11/19       #7: Crack repair ...
Matt
We've fixed more of these than I'm willing to admit.
We did it basically like Jonathan.
We opened up the crack, filled it with glue (we use thin CA mostly).
Then we sand the area flat, spot prime, and then recoat the whole door.
