Subject: Re: Matching Stain
Matching Stain
4/19/20
Clinton Member
Looking to match stain of the piece on the right.
Contracted to match a Fabuwood Finish for a built in and struggling a bit.
The white oak on the left is a test piece that I got close by mixing Minwax Puritan Pine and Gunstock I would like it to be closer. Specifically more golden.
Any input would be greatly appreciated and thanks in advanced
4/19/20       #2: Matching Stain ...
Jim Clark  Member
The only way I can match stains was to make
a sample of every stain I have and many
50/50 mixes of those on wood samples
that I finished. I get real close but just the
variances in wood can make differences.
It's a trial and error after that.
But having samples will show you which way to adjust.
4/19/20       #3: Matching Stain ...
Stop using big box store stain and have a pro finishing supply business help you match it. Either that or buy some universal colorants and use that to modify a base color.
4/20/20       #4: Matching Stain ...
mauricio poli Member
Why donīt you try golden oak minwax stain?
4/20/20       #5: Matching Stain ...
why donīt you try golden oak?
4/20/20       #6: Matching Stain ...
Nick
When matching a aged piece (especially on oak) not only do you have to match the stain but you also have to match the old finish as well. Sometimes it takes more than 1 step to get where you need to go.
The easiest way to put a little age on a stain is to spray on some thinned down Zinsser amber shellac after staining.if that is too orange making a toner with UTCs using some combo of burnt umber, raw sienna & yellow will get you where you need to get too.
4/21/20       #7: Matching Stain ...
Tyler
I'm with Rich. Get away from minwax first of all, find a dealer for ML. Campbell, Mohawk, or chemcraft stains. You send them your piece of wood you want matched, and the sample piece of wood you're staining, and they take care of the rest. They record and log all mixes, so if in 5 years you need to match that same stain again, they have it logged and you'll have your stain in a day. It's very convenient.
4/21/20       #8: Matching Stain ...
Jim Kolar
Did a lot of stain matches with Sherwin Williams but finally went with Chemcraft C - mix stain system. We are a small shop so this has worked out very well and saved a lot trips to the store and waste of stain.
This system has dyes that you can mix with the stain itself and get the darker colors. A good system for a small shop and not have the risk of over pigmentation of your stains.
6/8/20       #9: Matching Stain ...
Daniel Shafner Member
I like the way that Old Masters wiping stain works. I like the way that Varathane wiping stain works. I like the way that Minwax stains work. I like that I can get them locally.
Making your own color samples has a benefit over surrendering the process to some outsider. By you doing it yourself you become familiar with the tricks & techniques of color rendering, color matching. And you learn the working properties of your stains.
Factories and some shops can't afford the dry times of Old Masters, Varathane, Minwax. That doesn't mean that these stains aren't production friendly.
One thing to always be aware of is using these stains under catalyzed finishes, color shifting from the catalyst could occur if the catalyst reacts in an unwanted way with any japan driers that might be part of the stain. Easy fix, lock your stain in with vinyl sealer and now you have a suitable barrier coat & tie-in coat to start your topcoating onto.
    • 2Sand
