Subject: Re: Help with water base finishes
4/24/20
James Knowles
I am moving from solvent conversion varnish to water borne and need advice.
I am looking at 2 finish companies Renner and Milesi.
I want to use a tough catalyzed to replace my solvent MLC Krystal top coat.
I am looking for preference opinions about water base company's
4/24/20       #2: Help with water base finishes ...
Nick
I've been using Chemcraft AquaPrime, Aqualux and Aquaset for the last year and a half for WB jobs and am very satisfied with all 3 products. With the Aqua Prime being the star of the 3.
That said, last year l did a large job ( 15,000 linear ft. of trim, 50 doors & jambs and 400 linear ft. of cabinets) with Renner WB stain and WB clear finish) and was very impressed with both, So much so if l could l get a reliable supply of Renner products, l would use it.
4/26/20       #3: Help with water base finishes ...
Dan cook
I used to use aqua prime but it clogged up tips and everything else and was a bear to cleanup after using. Nothing seemed to dissolve it decently in the gun or anything it got on. We ended up going back to solvent based finish again after fighting with it for a year and a half.
4/27/20       #4: Help with water base finishes ...
James Knowles
Hi Dan
I know that the primer for renner is 53% solids. The needle nozzle size recomended is 2.0 up to 2.2, for a cup / compressor setup. Also it's been recommended to clean with acra strip "best web cleaner out there". Another recommendation is Citra Clean Concentrate. I know they always seam to say clean with water......never adequate for me nomatter how soon after I sprayed.....
Thanks jim
