Subject: Re: conversion varnish-wrong catalyst on first two coats
3/15/22
stoneaxe Member
Got a call from our finisher- the sealer coat and the first coat of conversion varnish were mixed with the wrong catalyst.
We use Sherwin V84 F82 varnish, with V66V21 catalyst, 3%.
They were shipped V66V22 catalyst and sprayed a sealer coat and first coat . Said the sealer seemed OK- like it soaked in and dried. Only noticed something wrong when the next coat did not dry.
They sprayed a third coat, catalyzed correctly, and the finish hardened up.
We have an inquiry with the rep about this, but I figured to check in here with the brain trust-
These are door parts, not a big job-but a high end one.
We could roll the dice and go, but I am worried about long term effects- I have seen incorrectly catalyzed C-varnish go all milky in a few years.
We could strip the parts and re-shoot, or I could just run the job again-two or three days work.
Any insight?
Thanks, stoneaxe.
3/15/22       #2: conversion varnish-wrong catalyst o ...
herb johnson
casinos always win in the long run which means you know you have a bad job going out the door.......
how much does it cost to p..s this customer off vs. redoing the job, getting the phone call , sending your people out when you are busy, waiting for the product to show up, on and on .........
you don't need anyone else's opinion, this is a cost vs benefit issue........tony soprano would "nip it in the bud"
good luck herb j.
3/16/22       #3: conversion varnish-wrong catalyst o ...
stoneaxe
Herb,
You are correct- thanks. I am going to remake this job -it is not worth the risk.
3/16/22       #4: conversion varnish-wrong catalyst o ...
You would also be knowingly selling a defective product to your customer. Moral compass is pointing to a remake.
4/30/22       #5: conversion varnish-wrong catalyst o ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
Conversion Varnish also has a nasty habit of cracking and crazing if not done right. I would redo.
