Subject: Re: Caulk before cv
Caulk before cv
10/20/23
Andrew
I'm spraying kemvar cv on cabinet doors and because of the termite/hurricane problems we have in the islands i used mahogany frames with pvc panels. If i were to caulk the panels in what caulk can i use with the cv?
10/20/23       #3: Caulk before cv ...
Leo G
I've used Bolt and Alex caulks without issues. Must be paintable caulks.
10/20/23       #4: Caulk before cv ...
PVC moves quite a lot with temperature change. Caulking may present some warping issues
11/1/23       #5: Caulk before cv ...
Nick Sinderson
For painted jobs (cv & wb 2k poly finish) I always caulk in the panels. I prefer using the hand held squeeze tubes to using a caulking gun...more control but harder on your hands. I've been using the Bolt 30 year with good success. Always caulk at least the day before finishing or your finish will crack on the not quite dry caulk. I live in dry climate, if you live in humid one chances are dry times will be longer.
