Subject: Re: Airless spray
Airless spray
5/9/24
John Barkes Member
Hi I have a 10 14 pump that works perfectly. I'VE put a new airless gun on it to spray fence panels pump works perfectly with just the hose put the gun on and nothing. Any ideas
5/9/24       #2: Airless spray ...
herb johnson
ideas, don't know what you mean, why buy a new gun if you already have a working mx , mvx or xcite gun...depending on what u r spraying viscosity wise, you many not have enough pressure to break up the material. if you can and want to hit it with ur best shot, buy a fine finish rac tip because the extra plate behind the tip, will pre atomize the material.
good luck herb j
5/9/24       #3: Airless spray ...
herb johnson
sorry i misread ur post. is the screen in the gun too tight, meaning too small a mesh, does material come out if you remove the tip. also the viscosity might be too much for the 10-1 to push thru with any type of restriction on the end meaning too small a mesh gun filter. i would try the gun with the tip off the airless gun. btw, how thick a material are u trying to spray, also, the size of hose id might be causing too much of a pressure drop when the gun is on the end of the hose.
5/10/24       #4: Airless spray ...
John Barkes Member
Sorted thanks apparently a 10 14 pump is not big enough to run a airless gun.
5/11/24       #5: Airless spray ...
Dave Edgerton  Member
Wrong application for a kremlin pump.
