Subject: Re: Waterbased / Waterbourne Clear on Maple
6/11/24
Kris
It's been a number of years since I looked at waterbourne finishes.
At the time I was fairly happy with the Satin General Finishes Clear Poly
I'm hoping that there have been some advances
We are looking at a project doing just clear maple with a clear satin finish
Is there something fantastic that has come out recently that I need to be looking at?
Any help would be appreciated
6/20/24       #3: Waterbased / Waterbourne Clear on M ...
Yavuz
YO-XXM718 Renner Natural Look 2K
6/27/24       #4: Waterbased / Waterbourne Clear on M ...
chris
there are many good w/b finishes out there. How durable do you need it to be?
you can use a water based lacquer or a 2Kurethane or something in between.
i would say an italian 2K urethane. personally I use products from Ilva.
6/27/24       #5: Waterbased / Waterbourne Clear on M ...
Paul Birmingham Member
Thanks Chris- I take look-
I would like them to be a durable as possible, practicle.
6/27/24       #6: Waterbased / Waterbourne Clear on M ...
Kris
Durable is important, but I'd rather a 1K product if possible
Ideally something with a bit of amber to it as well to match traditional Laquer or CV finishes
(General Finish Clear Poly is too crystal clear for this project after sampling)
6/27/24       #7: Waterbased / Waterbourne Clear on M ...
Jeremy
I used to use GF products but they are a 3 coat system. For the past five years I have used Diamond Vogel Aquinity waterborne acrylic finish. It is a single component, self sealing finish with two coats, 3 optional. It does have a slight amber color to it and they do offer an optional crosslinker for more durability. I have done many natural maple projects with it and have had great results with color.
6/27/24       #8: Waterbased / Waterbourne Clear on M ...
Kris
That looks like exactly what I'm after!
Looks like a quality product.
Now to see if I can find a Canadian distributor...
7/24/24       #9: Waterbased / Waterbourne Clear on M ...
Frank Garrido Member
Website: http://www.cabinethero.com
There are a few good water base coatings that are very durable , flexible and 2 part system.
ESC Coatings from Colorama has a full line of great clear options from single component WB clear {Spray Master) which I am actually using on Cedar siding for Interior Van paneling this week.,
They have a 2 part water base cv that builds really well called Con Var. . There water base Bar top finishes are really durable and have antiscuff properties]. Out door water Base Clear for front doors are really durable and flexible against harsh sun light conditions . they also have strong threshold finish clear and durable flooring coating as well. Many options to check out. Owner Rick T From Colorama is biochemist whose knowledge and expertise in developing these coating is awesome. When you speak to him he is really helpful in understanding your needs in achieving desired results you are looking for.
In a nut shell superior coating and superior customer service for sure.
