Subject: Re: Sayerlack Finish
Sayerlack Finish
12/5/24
Chris
Has anyone used this finish (Sayerlack) water based thinking about using on next set of cabinets. Thanks
12/7/24       #2: Sayerlack Finish ...
Mastercabman
Personally I have not
My local Wurth group is talking about bringing the brand but it's just talks
I wouldn't try a new product on a whole job
I would see if you can get a sale's rep to bring you some samples and try it before you commit
12/9/24       #3: Sayerlack Finish ...
chris
a SW rep showed me this finish and I was not impressed. The material was very thick like paint and did not spray well using HVLP gun.
might be better with air assist but I did not want to try as I normally spray solvent based.
Sayerlack carry a whole line of finishes so there might be one you like.
12/10/24       #4: Sayerlack Finish ...
Chris
I haven’t used it but my rep was telling me a lot of shops were using it. I will ask more questions thanks. What brand of finish are you using on your painted cabinets?
1/5/25       #5: Sayerlack Finish ...
Dennis A Thurman Member
Sorry im a month late. I have been using sayerlack for about 2 years or so. Absolutely love it. Im in a large custom cab shop that also does some furnitue. Lays out great with hvlp sprayers. I use a 1.4 tip off a pressure pot, but will spray just fine out of anything else. When you open the can it looks like eggnog but add 15% water mix and wait 10 minutes. my finishes in the shop are flawless as well in the field. I also use their paints with the same success. My fave is the 20 sheen.Hope this helps
1/5/25       #7: Sayerlack Finish ...
Chris
Thanks Dennis
I have decided to use their solvent base finish on this set I have had good luck with it in the past. I plan on using this new finish in the future though you sound like you really like it a lot. Thanks again
