Subject: Re: solvent base 2k poly
7/9/25
stan merritt  Member
My wife wants a live edge dining table of spalted maple with epoxy applied in the knots and holes in the wood. I've never sprayed 2k poly, but I have about 20 years working with conversion varnish. I would be using a C A Tech AAA 14:1 pump with Cougar spray gun. What information do you have for me regarding the best products, where to purchase (will distributors ship product to me?). I live in West Virginia.
P.S. Is it worth my time to use a 2k poly one time rather than just do what I'm accustomed to with the conversion varnish??
Thanks!!! in advance!!
7/10/25       #2: solvent base 2k poly ...
chris
I've been using 2K poly for past 12 years. Ilva products from camger coatings in Ma. also main distributor is IC&S in Pa.
I find it very easy to spray but you need to be careful. Pot life is about 2 hours. At this point it will harden and make clean up very difficult.
also you need to wear a supplied air respirator because of the Isocyanates in the catalyst.
The smell from the finish goes away very quickly compared to C.V. where the odor lingers for days.
For a full filled finish I spray polyester first then seal and topcoat with 2K poly.
7/10/25       #3: solvent base 2k poly ...
Fred Member
Hi Stan,
Solvent Based Conversion Varnish ( and Lacquer) and contains Formaldehyde. It gives up fumes for up to 2 months ( or so i have been told) in your house. That is why a lot of European Countries have not used it for close to 2 decades.
Everything Chris told you about Isocyanates applies with Polyurethane. Air Supplied Mask is a must in Canada if you use Polyurethane.
Isocyanates are cured the next day and you can deliver and install in your customers house without of gassing.
We use Polyurethane by ICA for finishing Exterior Doors.
7/11/25       #4: solvent base 2k poly ...
stan merritt  Member
Website: http://www.basicwood.org
Thanks for the info, gentlemen. I have some technical data sheets from ICA. Here's the information I have...
CLEAR PUR HC TOP COAT (OP384) has a 1-4 hour interval between coats
# of coat up to 2
Dry to touch at 45 minutes
Same specs as above for 2K CLEAR SB TCOAT G20 (OP383)
For FP271 2K CLEAR SB BCOAT
Interval between coats 1-3 hours
Dry to touch 1 hour
Sandable 12 hours
If I remember what some of you stated, the drying times and sanding times would be considerably longer than I expected. What am I missing??
7/14/25       #5: solvent base 2k poly ...
Bart
Why wouldn't you use an epoxy system after filling your voids? I've used West Marine 105 with the 207 hardener on a couple of live edge tables. Super easy. You don't have to torch the bubbles like some epoxy systems. I put a flat GF WB final coats over the epoxy to tone down the high gloss. I would imagine you could put CV over it. Test it out on the underside of the table.
7/20/25       #6: solvent base 2k poly ...
Nick Sinderson
I've had great success with ML Campbell Polarion.
That said l only use it on my jobs that need the highest quality of protection, look and feel (restaurant tables, wood sinks that l finish for a local woodturner [l've finished close to a hundred of these for him over the last 5 years without a single call back] ect...)
For cabinets, furniture store fixtures ect... l find the Euro Waterborne 2k polyurethane is a very capable product. I've been using the Gemini/Sirrca for 3 years now with good results and 0 callbacks or problems so far.
