Subject: Re: Clear Coating Maple without Yellowing
12/12/25
Michael R
What preparation must I follow in order to clear coat bright hard rock maple without changing its original color? Whenever I use for a sealer under my clear coat, I get a little bit of yellowing. Is there a way to keep the original unfinished wood color? Thank you.
12/12/25       #2: Clear Coating Maple without Yellowi ...
Chemmy
Use Acrylic coatings, SW, Delta, or others that are acrylic/cab coatings for indefinite non yellowing.!!
12/12/25       #3: Clear Coating Maple without Yellowi ...
Michael R Member
Thanks Chemmy!
I have been using Sherwin Williams Gallery clear coat, which is an acrylic and I still get a slight yellowing after spraying. Just to be clear, I'm not concerned about it yellowing over time because I am using an acrylic, I'm just trying to keep the bright Maple bear wood color using a clear coat. Are the products that you are recommending (solvent-based) designed to completely stop any yellowing? I know in your first reply to me, you used the words "indefinite non-yellowing. Should I expect a slight transformation after three coats, or should I see through it as if it were glass?
12/12/25       #4: Clear Coating Maple without Yellowi ...
cris
Whitewash then clear. you will have to experiment with it. We did this years ago and it worked great.
12/17/25       #5: Clear Coating Maple without Yellowi ...
Michael R Member
Cris, you nailed it! I did a test and the results are exactly what I was looking for. I got a quart of Zar Beach House #139 and applied to the maple let it dry, then two coats SW Gallery series acrylic. The Maple did not lose its bright white natural color and you can't even notice that there is a white wash stain on the maple. Thanks again, this one will go down in the books.
12/22/25       #6: Clear Coating Maple without Yellowi ...
chris vickers
I use Renner finishes, not sure if you are able to source it locally, but you can have it shipped. It leaves a totally clear finish on maple, cherry walnut etc. Been really happy with it. The 765 series can be catalyzed if you need the extra protection, but you don't have too. They do have a harder finish that must be catalyzed.
12/22/25       #7: Clear Coating Maple without Yellowi ...
Michael R Member
Thanks Chris. I've heard a lot about Renner and I know they make a great product. It would have to be shipped in but that's not a problem. Thanks for the info and Merry Christmas!!!!
12/22/25       #8: Clear Coating Maple without Yellowi ...
chris vickers
I love that finish line, been using it for a couple years now and won't use anything else. Best of luck.
Merry Christmas
12/25/25       #9: Clear Coating Maple without Yellowi ...
JeffA
Besides a white wash, I have put a small amount of white pigment in my clears to help keep it as non yellow as possible. I can't remember how much. If you do a self seal I can't imagine it's much more than 5 grams per quart. But I don't imagine as well as I used to......
12/25/25       #10: Clear Coating Maple without Yellowi ...
Michael R Member
JeffA, if that works, that would skip the process of wood stain white washing. Glad I created this thread because I'm finding many ways of holding the true value of maple wood color.
When I was picking up cherry veneer core many months ago, one of the warehouse workers said to me that I must have an unbelievable amount of years of experience in the cabinet making trade. I told him I am still learning and he thought I was kidding him. It's so true. That's the purpose of these woodworking and finishing chat rooms. Thanks again!
12/25/25       #11: Clear Coating Maple without Yellowi ...
Chemmy
Michael R, sorry for the long time to respond, I was in the hospital.
Your correct, what I was offering was bout the finish itself not yellowing, not the maple itself, the other responses were on target as to using pigmented toner or stain/ glaze. Just keep in mind that not all white stains are made from or with titanium dioxide,
and you will get long lasting results..!!
Merry Christmas..!!
12/26/25       #12: Clear Coating Maple without Yellowi ...
Michael R Member
Chemmy, Sorry to hear you were in the hospital, hope all is well now with you. Thank you for referencing the other posts are in good favor with you. I use Zar wood stain and they do use the titanium dioxide, which is good news because I've been using them forever. Thanks again for chiming in and reading through this thread and checking back!!
