Subject: Re: Spots after polishing
2/10/26
Cat Member
Hi there, I'm having an issue with this dining table. When it is polished with a non silicone spray polish (wood silk) it looks great, but when you come back after an hour then this odd spotting happens. It will buff back out but I just can not figure out why this is happening. The spots only appears around and imperfection like pits or dents.
This is also the case when a professional has removed the build up of whatever polishes were on it. However I'm experiencing the exact same result as before. Any ideas or suggestions would be greatly appreciated. Thanks.
View higher quality, full size image (4080 X 3072)
2/12/26       #2: Spots after polishing ...
My only guess is that the polish has gotten inside the wood and seeped through the pores and had a reaction of some sort.
2/14/26       #3: Spots after polishing ...
duster
Contaminants (wax, cleaners, or polish) have penetrated the finish through all the distressing. The only solution is to strip the finish back to bare wood and start over. Hopefully, the top is solid wood and not veneer. It'll take some agressive sanding to get through to clean wood before you can refinish.
5/2/26       #5: Spots after polishing ...
Fred Melton
This is cause some one used polish on it shop strips it put new finish on it ,it’s called fisheye from silicone in the polish .You can strip it again wash it down with acetone xylene mix spray very lite coat with fisheye remover in it .Fisheye remover can be bought from Mohawk finishes supplies .It is almost impossible to got silicone out of wood.I have tried it all next choice though it in trash
