Subject: Re: Spraying short boards in volume
7/12/26
BH Davis  Member
I'm going to be shooting latex paint on 1x4x(2' to 3') lengths of PVC part in volume. The PVC will be properly prepped and ready for paint. I may or may not shoot a bonding primer.....yet to be determined.
The paint is being applied to one face and all four edges. I'd like to place the boards directly on a spray table surface without raising them up with any sort of lift sticks. This will keep overspray from getting underneath and onto the backs. If that happens I can sand it off but would rather avoid that step without having to first mask the backs.
So the question is what material to use to cover the spray table that the paint won't bond to thus causing problems. I'm thinking of laying out waxed paper and seeing how that goes. If the paint doesn't stick to the wax paper I'll still likely have to lightly sand the back edges to rebreak/smooth out the edges after painting. Anyone have any experience with this sort of situation?
Thanks,
7/14/26       #2: Spraying short boards in volume ...
nicko
Can you buy a roll of rosin paper or brown paper from Home Depot and put a dowel through it and make it like a paper towel dispenser at the end of your table. And pull out the paper across your table and spray on it then just keep cutting it off with a razor knife and pull out another section and repeat.
You could make a quick dispenser out of a dowel and some scrap wood and mount it at the end of your table.
7/14/26       #3: Spraying short boards in volume ...
BH Davis  Member
Thanks for the reply. Unfortunately paper is not going to work. The whole point is to not use something where the paint will wrap from the 3/4" edge of the material down onto the table surface material. The paint would create a bond between the edge of the PVC boards and the paper. The result is that the paper will tear as the PVC is removed after painting and then have to be razor cut free from the PVC. I've been down this road many times which is why I'm looking for a material where the paint won't bond to the substrate.
It is a clever idea though. Early on in the CNC years back in the late 90's to early 2000's I did that paper roll idea at the end of the CNC table. Before getting the SL Laser that projected our curved moulding locations onto the CNC I set up a 6' wide roll of cardboard factory roll ends on top of upside down casters to create just what you are describing. Then a magic marker mounted in the spindle (not spinning of course) would draw the part location on the paper. Our vac pods were then mounted to the table inside the moulding lines to hold the blanks down during cutting. After 10 or so mouldings the paper would have so many magic marker lines on it we'd need a new sheet. We'd just cut off the old one and pull the paper off the roll TP style right up onto the table for a new surface.
7/14/26       #4: Spraying short boards in volume ...
Nicko
I was assuming you would be picking them up and moving them to a drying rack as soon as you sprayed them. Before the paint dried. Then roll out a fresh piece so you’re not laying them on to the wet paint you just sprayed.
7/14/26       #5: Spraying short boards in volume ...
BH Davis  Member
Ahh........yes, that would be nice. But there is really no way to pick them up with the edges as well as the face painted. It would make them much easier to paint as vs. spread out across several tables. But let me think more about that. Perhaps I can come up some sort of lift device directly under one end that would allow me to raise it and get my fingers underneath after painting. Thanks for the follow up.
