Subject: Re: SW EA Hydroplus
SW EA Hydroplus
8/2/26
Sapele101 Member
But the problem I have is that no one can answer, including Sherwin-Williams or Sames, what the exact filter sizes are to use without any guessing. I always spray with the super filter, Xcite gun handle filter and spray tip filter. I'm not sure whether I'm stripping paint or can go with a finer mesh. Since Sherwin-Williams has evaluated atomization characteristics for the EA Hydroplus using the 15C25, how can we determine the filter mesh size setup they used for this product and including Florenza for the 1K and 2K?
8/2/26       #2: SW EA Hydroplus ...
herb johnson
depending on how wide a pattern you want, a krenlin 09-092 or a 09-112.
the mesh size i use is the filter ending in 908, i believe it is a 85 mesh
i sometimes use a microscreen in the tip filter but most of the time i dont
just my two cents herb j.
typically around 40-50 psi on ther right reg and i only use whaatever it take s for the tails to go away, sometimes 15-20 sometimes a little more. i niever stick to an predetermind number one the atomizing air, just enuf to blend in the tails in the pattern, anymore than that ur just creating too much overspray. also on the eright reg, it depends also on how fast you mover with the gun.
8/2/26       #3: SW EA Hydroplus ...
Sapele101 Member
Johnson, thanks for the reply but that's not what I'm talking about. I'm strictly talking about filters dialed to specific coatings.
8/3/26       #4: SW EA Hydroplus ...
herb johnson
i will repost this
the gun handle filter i use is the gun handle filter ending in 908 that is the part number of the gun handle filter. i believe it is a 85
85 Mesh (Medium filtration): Part number 129-609-908
sometimes i use a microscreen the black one that goes inside the tip, i believe it is a 140 mesh.
