What finish to use on dyed veneer?
9/19/16
Tim Shelton Member
I have to do a full filled finish on a light grey dyed veneer. I was told that the finish should not contain an acid because it will react with the dye and cause it to change color. The veneer is made by Tabu, any suggestions would be appreciated. I want to use a polyester sealer to get the grain filled, but don't know if it will cause a problem.
9/20/16       #2: What finish to use on dyed veneer? ...
kevin
We finish a ton of grey tabu veneer. Let me say this, no matter what you put on it, it will change color. It will still be grey, but not the same exact grey that it is when not finished. Tabu veneers are also NOT light fast and will shift colors once installed very quickly. Ive seen panels shift colors inconsistently as well (half of one panel shifts and then maybe a panel 3 panels over shifts)
The best results ive gotten as far as maintaining original color was to use very thin coats of dead flat lacquer. Not very durable, but when the designer is insistent, you do what it takes.
Not that thats going to help you because your looking to fill the grain.
Try a dead flat poly from ICA. ive had good results with that on other projects. But be aware, all designers/clients buy tabu veneers and expect it to look exactly like the veneer sample they got that has no finish on it. Dream chasers!
Good luck
9/22/16       #3: What finish to use on dyed veneer? ...
RobertJ
Read the PDF file at 'Mundy Veneer' for finishing. They suggests, as above, ICA exterior Waterborne acrylic coating.
May want to ask other manufacturers:
Target, Valspar, SW what they have to offer.
SW now carries several coatings from ITALY.
9/23/16       #4: What finish to use on dyed veneer? ...
ronb
Website: http://www.ronbryze.com
Hey Tim.
The biggest problem with Tabu is the color fading from exposure to UV. Our company has worked closely with Tabu for several years to develop products that will minimalize this effect.
The best bet is an acrylic system. Milesi has an acrylic sealer that contains a UV additive. there is also a UV additive for the acrylic topcoats. As far as a full fill, as you know acrylics are not the highest building, so this is the trade off. Polyester will give you the build, but the yellowing will shift you color over time.
There are also self sealing "natural effect" 5 sheen products that can reduce the color shift due to the wetting action of the finish on the surface of the wood - available in water and solvent base. The UV additive can be used in the solvent base version. They are a 5 sheen and unfortunately have a very low build.
Several options, but unfortunately not 1 that fills all of you needs.
Good to hear that you are back in the biz.
Ronb
