Spray gun shoots fluid only when trigger first pulled
9/30/16
Carmine Member
I had a friend give me his Devilbliss vtx spray gun and pot. When the trigger is pulled the gun first produces a fluid stream with no atomization for a split second (the first 1/8" of travel of the trigger) until the trigger is pulled further. Then it sprays normal after that. The same thing when releasing the trigger. The last 1/8" of travel is fluid only.
Anyone know the cause.
9/30/16       #2: Spray gun shoots fluid only when tr ...
herb johonson
probably want to check the air valve stem that is locating under the triger, push it in and make sure it travels freely some gun lube should really help
keep us posted
good luck
herb j
9/30/16       #3: Spray gun shoots fluid only when tr ...
Eric Member
If a friend gave you the kit...I will assume you need to brake it down and give it a good cleaning..most gun diagrams are found at DeVillbiss web sites..
They are fairly simple to work on..rebuild kits are about 20.00
9/30/16       #4: Spray gun shoots fluid only when tr ...
Bad seal of dirty gun somewhere. Also check the fluid pressure at the pot.
