Pilling or corns
11/2/16
Jim
Wasting time cleaning my sandpaper.
So when I am using my random orbit sander on an old finish, inpreperation for a new finish. I have to stop often and scrape off the small spects/small lumps of finish buildup.
In thinking about it, are the corns coming from "loose" sanding finish dust or right off the finish it self? I am not using a vacuum. I am using Klingspor PS 33 paper
Improvement thoughts??
In this instance I am sanding to raw wood to remove old deep scratches . If just refinishing I would use my Surfprep for coat adhesion and not remove the entire finish.
11/2/16       #2: Pilling or corns ...
My opinion, it's the heat that causes your problem. Alternatives are strip the clear coat, use a card scraper, use a vacuum on your sander, or use courser abrasive.
