Polyester
2/24/17
Dan cook
Who can tell me about polyester coatings and their difficulty as opposed to post cat conversion finishes. Or are 2k urethane easier to work. I have not used either but I'm looking to them for high build finish.
2/24/17       #2: Polyester ...
chris
I use both from ILVa coatings.
the polyester i use to fill the grain followed by 2k acrylic sealer then topcoat.
I spray a barrier coat first as polyester does not bond to oily woods then after 2 hours i spray a heavy coat of polyester.
i leave overnight then use a widebelt sander to level the table tops.
I then seal sand then topcoat.
This is a relatively simple system to use and produces a very hard durable finish.
2/25/17       #3: Polyester ...
CraigM
They work well for build, but you have a very short pot life. I don't even leave it in the gun when I go for lunch.
2/26/17       #4: Polyester ...
chris
polyester has a 30 min pot life and 2 k urethane has about 2 hr potlife
