Good airbrush for touchup with conversion varnish?
3/16/17
Matt
Anyone have a recommendation for an airbrush for doing minor conversion varnish touchup in the client's house?
This would be for areas that we're just trying to lay down a layer of color, such as on scuffed baseboards. NOT trying to build up normal thick film layer.
3/16/17       #2: Good airbrush for touchup with conv ...
kevin
C A Technologies Techline JR. . is a compact hvlp that can be dialed in to spray as fine as a marker or can be opened up to spray a few inches wide. Great for touchups.
Airbrushes arent great for conversion varnish do to the viscosity. Its hard to get the material out.
Either way you go, your still going to have the halo around your spot repair. Conversion varnish doesnt "blend in" like lacquer. There will always be a hard edge.
3/16/17       #3: Good airbrush for touchup with conv ...
Matt
You're absolutely right about the halo. I've found that using really slow thinners as a fogged-on blanket overcoat, like butyl acetate, you can get a pretty good feathering-in but nothing ever sheens out as nice as a full 3 mil coat.
That only works with duller sheened items like 15-30 sheen.
I'll look up that CAT spraygun. My AAA's and gravity feeds are all Cougars and Jaguars, so I know they are good.
3/16/17       #4: Good airbrush for touchup with conv ...
Mike Soaper
I suggest you take a look at the Homestead Finishing Products QS-125, and give Jeff a call as he also carries some CAT guns and might be able give a comparison of it and the Jr.
3/16/17       #5: Good airbrush for touchup with conv ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
For minor touch up I would recommend either Konig Special repair Aerosols http://www.konigtouchup.com/BuyNow/specialrepairlacquer.html
Or Mohawks Perfect Blend aerosol.
http://www.mohawk-finishing.com/catalog_browse.asp?ictNbr=703
For an airbrush I like Iwata, the Eclipse or the Revolution. For spraying CV touch up I think I would go with a detail gun though. Low pressure and a lot of retarder like MAK.
3/17/17       #6: Good airbrush for touchup with conv ...
Shane
just a side note on the tjr jr.... on finish systems.com in the econmy gun section you will find a gun that looks identical to the tjr gun .... just doesn't have the cat logo or come with a hard case.... much much cheaper and same gun. I bought a few of them over the years.
http://www.finishsystems.com/economyhvlpandrpspraygunsairbrush.html
