hvlp
7/6/17
Jim Member
Spraying thinned cat laq for sealer coat with fugi semi pro2 using qt.cup.
After I set it down for a bit and start shooting again there is hardly any material coming out.It was shooting perfectly 10 minutes ago. Any ideas?
7/6/17       #2: hvlp ...
Nick
it could be a number of things but the most likely answer is that a drop of lacquer got past the nozzle then dried leaving the orifice a fraction of its intended size. dip a soft gun cleaning brush in lacquer thinner and clean the drip off.
7/6/17       #3: hvlp ...
Dave L
Build-up on the tip or inside the low pressure line to/inside the cup... I found the one-way valve to be more trouble than its worth and got rid of it a long time ago.
7/6/17       #4: hvlp ...
Mastercabman
You may also want to check the little air tube going into the cup
If it's clogged up you won't see much material
Also check the cup lid where that hose comes in
7/7/17       #5: hvlp ...
Jim Member
Mastercab man hit it.
Problem solved.
Many thanks.
7/7/17       #6: hvlp ...
Bart
Gravity gun. Problem solved. You can go real cheap for what you're doing.
7/10/17       #7: hvlp ...
chris
why dont you spray a sanding sealer?
it sands a lot better than topcoat.
8/24/17       #8: hvlp ...
ColorPro Member
Chris makes a good point, sanding sealers are far easier to work with than any top coat.
but in using any cup guns, be it grav or siphon. I have a regiment that I go thru when ever I leave it set for a few minutes or more.
pull off air cap and soak,
before spraying I pull out needle, clean tip.
clr fluidtip.
put gun back together, and clr the air valve on cup..
shoot product.
I use pps or dekups disposable cups 99% of the time..saves me from having issues from cups getting plugged up.
