Custom white lacquer
1/11/18
Stefano
Hello, I making a project with maple painted on white. I need to match the paint that I'm spray on maple with white paper that has light warm tone. I had the water base lacquer tinted by a store and the color match well the paper but the problem is that once I spray the white tinted color over the white primer then the white is no longer match the example probably because the primer is slight darker of the white and has kind of blue tint. Should I try to add some white to the primer?
Thank you
Stefano
1/11/18       #2: Custom white lacquer ...
Tyler
Just do an extra coat of the top coat and you should be fine. You just need more build.
1/11/18       #3: Custom white lacquer ...
Have them tint the primer.
