kremlin 10-14 pump problem
4/17/18
Jeff
I just rebuilt my 10-14 with the fluid kit ( both balls gaskets and o-rings ) now i can't get the motor to pressure up past 2 bar? it keeps on cycling like it does when priming but won't build pressure until i turn it down to around 1 bar then it will pressure up and stop cycling????
4/18/18       #2: kremlin 10-14 pump problem ...
Shane
did you clean all the parts very well and replace all the orings? Sounds like one of the balls is not seating and not allowing it to build pressure or you have a leaky oring.... did you grease all the threads orings and throat seal before assembly?
4/18/18       #3: kremlin 10-14 pump problem ...
Bruce Member
This is the recommended grease Kremlin uses
View higher quality, full size image (970 X 980)
4/18/18       #5: kremlin 10-14 pump problem ...
Jeff
Thanks for the replies guys ends up i put the nylon seal on the large ball cage backwards....did this rebuild more times than i have fingers and just when you think ya know everything..LOL
