pressure problem
9/24/18
Tony
I'm looking for some advice to hopefully point me in the right direction since there are so many variables. I currently spray pre and post catalyzed lacquer using a 2 1/2 gal pressure pot with a LVLP gun. I spray approximately 3-5 gallons of primer/clear a week and have used this same setup for 20+ years (although I have changed guns over the years.)
Just in the last week I have been having a problem losing pressure at the gun. When I first trigger it, I get a large burst of pressure, then as I spray, the pressure slowly drops. I first get too much air and very little fluid. As the pressure drops, I get more fluid and more texture. I have tinkered with both regulators, adjusting the air up and down. When I get it high enough to atomize the spray to an acceptable level, I get dry spray. then as the pressure from the gun drops, I get too much fluid.
I have one regulator at the tank "air inlet" and another one after that that I set the pressure off the gun. I am getting steady pressure from the compressor, as I don't get this pressure drop when the tank and fluid are not pressurized. Or when I use the air just through a blower nozzle. Any suggestions to get me started in the right direction would be appreciated. Should I change both regulators, or break the gun down to ensure it's clean (I don't always break it all the way down, but often just clean the nozzle and cap). I can do all the above, but really want to know what is causing it if possible.
9/24/18       #2: pressure problem ...
herb johnson
i believe you have an internal issue inside your regulator, inside the regulator there is a diaphragm that over time hardens and does not have flexibility it did when new also there is a stem and seat{some times the stem seal wears adn or gets dirty, that the diaphragm pushes down on , typically i wouldn't take the time or money to put in a regulator kit, just get a new regulator also depending on the pot, the first regulator inline has one unregulated port that supplies main line pressure to the atomizing air, if you have further questions let me know what make pot you have and i can help steer you in th eright direction reulgators are pretty cheap i would just end up changing them out, max 120 for both
good luck herbj
9/25/18       #3: pressure problem ...
Tony
Herb, thanks for the response. It was the regulators!
