Chemcraft Aqualux
2/16/19
Jonathan Mahnken
I've had two orders of Aqualux Uniclear show up from Wurth Louis and co(Utah branch) that have had particles in it which I cant strain out. The first order was pigmented and the second clear satin. both have visible particles in the coat after being sprayed. Yes I have checked my spray rigs. all are running clean. I run 100 mesh screens on the pickup and at the gun. Ive even tried straining manually. Can this happen from the product freezing during shippment?
2/17/19       #2: Chemcraft Aqualux ...
Dan
Going down another path.... Did you happen to change sandpaper? I once blamed the finish and it ended up being the sand paper I was using. .
2/18/19       #3: Chemcraft Aqualux ...
mauricio poli Member
Hello Jonathan, yes I believe freezing could had create these particles. You must complain and ask them to change the material and take care on shipping.
2/18/19       #4: Chemcraft Aqualux ...
Jonathan Mahnken
Thanks Mauricio! im pretty sure thats what has happened. I did a brushout on a piece of glass and you can see these clear gelatinous particles in the coat. Dan Ive been down that road for certain. I learned long ago to stick with top quality sandpaper and a calculated finish schedule.
2/24/19       #5: Chemcraft Aqualux ...
Garen Pletzer
I have seen like a light brown stuff from some of their conversion varnish and pre cat. Not sure if its the same but i strain it and still gets threw but gets stopped in the gun filter.
3/13/19       #6: Chemcraft Aqualux ...
jonathan mahnken
The material had frozen. I notified Wurth and it was replaced
