Clear epoxy over plastic laminate
3/3/19
Bob
Does anyone have experience with pouring clear epoxy on plastic laminate? Our local fire department wants a table that is black with red trim around the outside edges. They want their department emblem in the center and several badges and other items placed in the corners. The idea is to pour the epoxy over everything to protect and have a smooth surface. My concern is the epoxy adhering to the slick surface of the laminate. Looking for ideas or suggestions.
3/3/19       #2: Clear epoxy over plastic laminate ...
There is a difference between epoxy and casting resin. Make sure you get something that doesn't quickly yellow. Personally, I would have the badges under a layer of tempered glass. It will stay permanently clear and will not destroy the badges. I'd get the emblem printed at a sign shop in vinyl and stick it to the laminate.
