Finish room setup
3/31/19
Chris Member
Looking for tips suggestions for setting up a dedicated finish room. Current shop space is 30’x45’ and every time I need to spray, I have to shut entire shop down. Will be adding on a 15’ by 25’ structure this fall and am looking for suggestions on ventilation systems, storage/drying racks, lighting, heat system (have a ceiling mount propane heater for main shop), etc.....Want to do it right first time, any and all suggestions welcome!
3/31/19       #3: Finish room setup ...
Chris Member
Little more background....I’m a one man shop doing mainly custom cabinetry but do some furniture and other odds and ends from time to time
3/31/19       #4: Finish room setup ...
CraigM
It depends where you are located. If you want/ need everything to be legal, the NFPA 33 guidelines are a good place to start. Check with your local government to see if they require more. I've been through two finishing shop setups from scratch and have had the company that I bought the booths from handle the engineering and permits, it was much simpler than doing it myself.
4/3/19       #5: Finish room setup ...
Matt Meadows
Try to get LED spot lights in at least a few places, especially where you spray, because the "point source" they produce can work wonders helping you see how your finish is laying flat. Fluorescent can help with that too but LEDs are even better, I've noticed. Use "more small ones", not "less big ones".
Talk to your spray booth supplier about mounting the fan and motor outside the booth and add sound damping panels everywhere you can. I've sprayed cabinets for 15 years at this point and the older I get, the more I utterly despise how loud most spray booths are.
