staining alder
6/4/19
Matt Atkinson Member
Techniques for minimizing blotchiness on stained alder? Ideas?
6/4/19       #2: staining alder ...
jonathan mahnken
waterbased stain works. or you can try a wash coat or stain conditioner
6/4/19       #3: staining alder ...
dan shaf Member
Sand evenly. Finish sanding 150 grit with the grain. Apply clear stain base. Let it set. Lighly sand. Apply your wiping stain, finish by wiping/brushing with the grain.
Or, instead of a wiping stain, spray an NGR dye stain. Still use the clear stain base as I described above.
6/4/19       #4: staining alder ...
Shane
Reduced NGR spray stains.... lowered air pressures and multiple passes are your friend..
6/5/19       #5: staining alder ...
JeffA
Alder = poor mans cherry.
Back in the day we would put in the wipe stain a product called bentone. Since alder is so soft and porous the bentone will fill in those areas and help the wipe stain not be blotchy. As a warning, once bentone is added to the stain, it can't be used on anything else but alder. If you use it on oak or maple, you could have adhesion issues.
6/11/19       #6: staining alder ...
John Member
I used a gel stain with wood conditioner and it turned out pretty good.
