Sherwood HB CV?
6/14/19
earworx Member
Anyone tried this yet? Just shot my 1st small job. The ability to have custom pigmented Conversion Varnish ready in about 1 hour vs 4-5 days is great.
One downside is pot life is 8 hours and temp is supposed to be above 70 F
6/17/19       #2: Sherwood HB CV? ...
Shane
Yes... This is an excellent varnish! It's essentially the Becker Acroma Matador that Sherwin absorbed...… Once you get your reduction cocktail just right this stuff lays out and is crazy smooth to the touch...
6/17/19       #3: Sherwood HB CV? ...
earworx Member
20% right? I noticed there was no viscosity
reference on the data sheet.
6/17/19       #4: Sherwood HB CV? ...
Shane
yes.. I reduce it with about 20-25% butyl acetate.. 5% butyl cellosolve and I use the Slow catalyst as well...
6/18/19       #5: Sherwood HB CV? ...
dub
I've sprayed one small project with this product. I used the slow reducer the supplier provided. The color I sprayed was very dark gray and seemed to cover well. As with most dark colors, I ended up topcoating with clear CV.
I don't like have yet another cat. mix ratio (16%), but did like same day color mixing.
dub
