ICA over Extira
8/1/19
Fred
Anybody have experience with finishing EXTIRA MDF exterior door components ( in this case raised panels with ICA? Problems are high prep time due to wave pattern on the surface. This pattern seems to be in the board and does not disappear with sanding in wide belt sander to 150 grit and then orbital with 150. This is still visible after sanding to 150. Requires lots of primer and re sanding to make the pattern disappear. It tends to reaper after finish dries.
8/4/19       #2: ICA over Extira ...
Sounds like there is a higher glue/resin area in that piece of Extira. You are getting print thru the finish. That one spots hardness is different enough that you can see it. Kinda like putting a streak of Bondo across any kind of panel. It will always show thru the topcoat because of it’s hardness.
I would bury it under a couple of thick coats of primer.
8/5/19       #3: ICA over Extira ...
shenendoah
perhaps a good coating of ICA polyester sealer to lock it all in, then level sanding, prior to primer/ paint
