retarder names and crosslinking
8/16/19
paintdude
I have a rep telling me that Butyl Cellosolve, Ethelyne Glycol and something called EB are all the same thing.
I know finish manufactures and suppliers love to play name games with products, but I need to sort out the nonsense in this particular situation.
Also, I've always been told that Butyl Cellosolve can slow cross linking when used in catalyzed finishes rather that just extending open flash times. But this rep is telling me that's not the case.
What's the straight scoop here?
8/16/19       #2: retarder names and crosslinking ...
Daniel Berlin
Butyl Cellsolve = Ethylene Glycol Monobutyl Ether
It is the butyl ether of ethylene glycol.
One of the trade names is EB.
(Dow, Eastman, and Jeffersol produce it).
So it is *not* the exact same as ethylene glycol, but it is the same as EB.
8/20/19       #3: retarder names and crosslinking ...
Paintdude
Thanks,
Any info about EB, ethelyne glycol affecting cross linking and cure times of catalyzed finishes?
8/20/19       #4: retarder names and crosslinking ...
mauricio poli
Hello
It Does not react with the resins or with the crosslinker.
Just reduces evaporation ratio of the coating.
Good luck
8/21/19       #5: retarder names and crosslinking ...
Brian Member
Do not use Butyl Cellosolve in a post catalyzed coating. It will affect how the system cures, use Methyl Amyl Ketone to retard post catalyzed coatings.
8/21/19       #6: retarder names and crosslinking ...
DannyB Member
It is not that simple.
There are plenty of post-cat's where butyl cellosolve is the recommended retarder (not reducer).
See https://www.paintdocs.com/docs/webPDF.jsp?SITEID=SWOEM&lang=E&doctype=PDS&
amp;prodno=V85F355
and
https://www.acromapro.com/document/PDS/en/DM5610003/ACROMAPRO
for example
8/29/19       #7: retarder names and crosslinking ...
cwk
iv'e used Butyl Cellosolve in guradsman, lilly, seagraves, cambell,etc etc post cat products over the last 30 years. never a problem. no more than 2% ever. I won't use in in PU's or PE's.
