tack clothes w/Conversion Varnish
8/27/19
cabinetmaker
Never used tack clothes with anything but automotive
Just starting to spray a lot of conversion varnish
Are these ok between coats ?
8/27/19       #2: tack clothes w/Conversion Varnish ...
Robb Parker  Member
We don't use tack cloths for fear of contamination. We use microfiber cloths. Last forever and can wash. Combination of air blow off and microfiber works for us.
8/28/19       #3: tack clothes w/Conversion Varnish ...
Jim Clark
I know many finishers won't believe this
but all I've used for the past 15 yrs on
all my woodwork and auto finishes is
Endust on a clean shop towel for final
wipe down. Not to be confused with
Pledge which is a wax, Endust leaves no
residue and also takes the static out.
I'll never use tack rags again.
I just throw the towels in the washer
when done and reuse, they just get better
with age. And NO I have never gotten a
fish eye using Endust.
8/29/19       #4: tack clothes w/Conversion Varnish ...
CraigM
I've used tack cloths for years on precats, postcats, cv's, and 2k poly and never had an issue.
8/29/19       #5: tack clothes w/Conversion Varnish ...
Matt
Tack cloth isn't likely to contaminate anything, the minuscule amount of residue it leaves isn't going to hijack anything.
However, I've sprayed CV since 2004 and never needed a tack cloth. Usually just a good "textured" shop rag will work. Something that has the texture of a bath rag works fantastic in most cases.
I've also had seasons (especially in cool weather when CV cures slower) that a very fine grit sanding sponge was the best--- it easily knocks off small dust fingerprints. In cool weather, the slower curing can result it clumpy, sticky dust.
9/5/19       #6: tack clothes w/Conversion Varnish ...
Gary
Agree with Craig M I've been using tack clothes for years with Solvent, water base and even powder coating and never have had an issue.
