Gold lettering onto wood
9/3/19
Andy Member
I have a job where I will need to put some small gold lettering onto mahogany. It needs to be durable and detailed. The entire area is about 1” x 2”, and I will have reproduce the letters multiple times.
I have a CNC, and I was considering doing a brass inlay (or possibly something softer). That seems like it’s going to be the most time-consuming method.
My wife had a Cricut, and I can easily get the letters cut out on that, but can I cover it with lacquer? I also don’t know why type of material to use.
Anyone got any other suggestions? I’ve never worked with gold leaf. I thought of maybe cutting the letters out of the wood on my CNC and, instead of doing and inlay, painting gold in the relief and sanding away the excess.
9/6/19       #2: Gold lettering onto wood ...
Denny J
How about carving the letters with the cnc and doing a metallic gold pigment in epoxy?
9/6/19       #3: Gold lettering onto wood ...
Andy Member
I'm considering that, but it will probably be the most complicated option for various reasons. One is that I am afraid I might lose some of the detail in what it is quite small logo lettering. I do have a 0.0197" bit. I can at least model it and see what it looks like in a preview.
I think I am going to first try deco foil and heat applied adhesive sheets. I can cut the logo out of the sheet adhesive with the Cricut and then transfer onto the wood between several coats of poly or lacquer.
We'll see how that goes.
