Exterior door
10/11/19
Joseph Eultgen
What are a finishers thought in the best finish for an exterior door?
It has a a large 10 foot roof over the front door to give pretty good protection from direct weather elements
10/13/19       #2: Exterior door ...
Bob Niemeyer  Member
All the European companies have very good exterior finish systems both in solvent and water. Let us know your location and we can direct you to the proper Dist. for products and support.
10/13/19       #3: Exterior door ...
Joseph Eultgen
I am in Columbia ,Missouri. 2 hrs from either dt Louis or Kansas city
10/14/19       #4: Exterior door ...
Shane
Are you finishing over an existing finish? What is the door facing towards sun exposure? Facing east facing south etc etc.
At the minimum your looking at 2K exterior if you want something to hold up for a while.
10/14/19       #5: Exterior door ...
JaySun
MLC has a pretty good system Polarion X Acrylic 2K sealer and topcoat.
10/14/19       #6: Exterior door ...
Tyler
I have had nothing but success with Chemcraft's D-Dur
10/14/19       #7: Exterior door ...
Joseph Eultgen
It's a new set of double exterior doors quarter sawn Mahogany. Facing west but a 10 ft deep covered porch. Thank you all for your response.
10/14/19       #8: Exterior door ...
And how will any of the above finishes do when it comes time to recoat or remove them?
Sikkens is designed to fail in a way that makes it easy to recoat and easy to remove. should that ever be needed.
West facing UV will be worse than rain ever can be. Your definition of a 10 foot overhang is vague: 10' high as in off the ground, but then what is the projection? 10' from the face of the doors to the edge of the overhang? This is usually all spelled out in your warranty. How do you handle this overhang in your warranty?
10/14/19       #9: Exterior door ...
Bob Niemeyer  Member
Joseph, sorry for the delay just wanted to talk to the rep before I post his number here.
Call Todd Gregg @ Integrity Coatings 913-208-8584. He will get you hooked up with an ICA Ext. System in solvent or water. He can tell you the pros and cons of each. Both are proven systems that will last. Todd knows his stuff and wont feed you any crap.
10/18/19       #10: Exterior door ...
Old school is to spray (4) coats of Interlux spar varnish.
New school is a exterior 2k like MLC Polarion.
Smart school is something like Sikkens which can be maintained by the homeowner or a house painter.
The cabinet finishes look great 5 years in good conditions then the maintenance becomes an issue. The customer can’t even purchase these products.
On the big houses the Builders & Architects will still spec the Varnish. Knowing the above.
Keep in mind these are not cabinets or tables.
10/18/19       #11: Exterior door ...
Nick
I've found that applying a coat of clear penetrating epoxy sealer first will extend the life of both spar varnish and 2k poly exterior finishes. Of course the length of that time is dependent on much rain, snow and sun the door will be subject to.
10/18/19       #12: Exterior door ...
Nick
PS; l usually offer a maintenance contract for exterior doors, Where l look in on the condition of the door every couple of years then when it looks in need l apply another coat or two on-site before finish failure sets in.
