Varathane oil-based semi-gloss polyurethane
10/25/19
Ken Member
Just wanted to share my experience with this finish and get any advice you might offer. I had problems applying this on a newly made cherry coffee table top. The instructions say not to to thin it but it is so thick out of the can that runs, drips and puddles are unavoidable, leading to a several rounds of sanding and recoating. The finish clogs the sandpaper very quickly making sanding frustrating. I eventually got acceptable results by thinning 50-50 with mineral spirits or naphtha and applying with a chinese bristle brush. After drying I used 0000 steel wool to smooth and applied a coat of wax to get a smooth finish. Telephone technical support was not very helpful. This type of barrier finish is more protective but less natural looking and less beautiful than a penetrating finish on a fine hardwoods like cherry. I will stick to danish oil in the future. Thoughts?
10/25/19       #3: Varathane oil-based semi-gloss poly ...
You're using a finish like that in a professional shop? I have no idea what went wrong where the bottom shelf intersects with the leg/ Looks like you left it full of glue squeeze out.
10/26/19       #4: Varathane oil-based semi-gloss poly ...
Ken Member
Only the top is new. Base is 20 years old.
10/26/19       #5: Varathane oil-based semi-gloss poly ...
mastercabman
I just build and finished a hickory wood top with the same product (satin)
Was not my choice but I'll never use it again!
Too thick to spray and did not want to try thinning to see if it would be able to spray
I put multiple coats, sanding between with 220
Just to discover runs and drips!
I did a final sanding and applied 1 final coat with an aerosol can of the same product
Turned out ok
That stuff is for your average Joe with little projects around the house
Not my cup of tea !
