Fastest way to finish sand outside corners
11/3/19
Nick Kaplan Member
Website: http://puck-em.com
I make wooden knee sliders for motorcycle roadracing. The are a simple square or rectangular shape. I route the edges and corners then hand sanding the corners. It takes a very long time and I’m looking for a way to sand the finish sand corners mechanically. Does anyone have any suggestions that will speed up the process? Flap discs? Brush flap wheels? Thanks in advance!
11/3/19       #3: Fastest way to finish sand outside ...
Have a look at a pedestal sander with an inflatable drum sander on one side and a flap wheel on the other. You could also have a buffing wheel for high gloss finishing.
11/4/19       #4: Fastest way to finish sand outside ...
D Brown
A profile sander will do the job..
11/7/19       #5: Fastest way to finish sand outside ...
Denny J
Look at the SurfPrep 3x4 sander and the 1/2” foam pads. They will contour perfectly
