water base question
11/16/19
Shep85037 Member
Hey guys I am looking at getting into spraying waterbase and just wanted to get some feed back from the pros.
I have an AAA for shooting precat Laq and I was wondering what equipment you guys use for waster base Laq ? I am experimenting with Ml Campbell Aguelente and I dont know if I should get a pressure pot, hvlp gravity fed gun, or use my AAA or use a standard Airless rig like a graco .
Any help would be much appreciated thanks
11/16/19       #2: water base question ...
david zaret Member
we shoot waterbased with both HVLPs and a kremlin AAA. the key is finding the right tip, and then, of course, proper pressure and air settings.
for sayerlack, i shoot with the 06-094 tip, ~55 fluid, ~12 air.
11/18/19       #3: water base question ...
rick
the answers above are all good, for myself, if you are a craftsman who understands the fundamentals of spray application any delivery system will give you good results.
the differences would come from the location ie . booth or on site and the overall environment. in short , from prep to curing environments these factors are just as or more important than the application equipment.
the chemical reactions in waterborne differ greatly from solvent materials. read the specs. thoroughly and contact the mfgr. but remember their experience is in a controlled environment and that is rarely the case for us finishers. so, shoot with your current knowledge and adjust from there, it may have a different name , however, it is still a liquid that needs atomized and in this case dries quicker.
my 44yrs advice says load it shoot it and make necessary corrections. if it dries fast don't break it up so much and visa-versa, look for the flow you are a professional so do what is right. can't go wrong!
thanks for reading rm..
11/18/19       #4: water base question ...
Jonathan Mahnken
stay with AAA. MLC sprays easily through hvlp as well though. Some WBs are much thicker and its just easier to mash them through an airless type tip
11/18/19       #5: water base question ...
Pat
Practice before you attempt a real job. WB may be more prone to runs and sags and takes longer to dry. Product chemistries can also be different from product to product, so be careful about using different manufacturers' stuff (stains, primers, color, clearcoats, etc.) on a single job. I've been spraying only WB for 15 years, and AAA is definitely my preferred way to go.
Cheers,
Pat
