Topcoat adhesion problems with factory primer
12/18/19
Derek Member
Good morning,
We are having adhesion problems with our topcoat to our door manufacturers factory used primer. We are spraying with the water based emtech 6500 pigmented topcoat. We sand the primer with 220g prior to the first topcoat. Once cured, the finish does not pass the fingernail test.
It seems whatever we sand with, adhesion is still an issue. Is the water based lacquer unable to form any kind of mechanical bond with the solvent based primer? Any recommendations?
I spoke with the finisher at the manufacturer and they haven’t came across this issue.
12/18/19       #2: Topcoat adhesion problems with fact ...
arthur grudko
Does Emtech recommend spraying their waterbase over a solvent base primer?
12/18/19       #3: Topcoat adhesion problems with fact ...
rescraft
Give Target a call or browse one of the forums there. The owner Jeff takes calls and could advise.
12/18/19       #4: Topcoat adhesion problems with fact ...
Pat
Finish chemistry incompatibility? Switch to a different vendor for your doors or finish, prime the doors yourself, or ask your door vendor to use a different product?
I spray a ton of that Target product, and have not seen this. I don't buy my doors primed, but I routinely spray pre-primed mouldings with no problem.
Cheers,
Pat
12/18/19       #5: Topcoat adhesion problems with fact ...
Have you primed with a Target primer and then top coated to see if the issue goes away?
12/18/19       #6: Topcoat adhesion problems with fact ...
Bart
I'm with Leo here. Do a spit coat of Targets sanding sealer. Scuff sand and then a flush coat of SS. Then your topcoat.
My2cts
good luck
12/18/19       #7: Topcoat adhesion problems with fact ...
What's the advantage of ordering the doors in primer? I'd think you would often require a touch up on the primer before painting anyway because of shipping and handling.
