Air powered mixer
1/1/20
Tom
I'm ready to switch from an electric drill for mixing 5 gal cans of CV to an air powered drill was wondering will a cheapie Harbor freight drill work? It appears they are single speed and not variable ,so I'm guessing I would control the speed with a shut off valve on the airline? Would love to hear from anyone using this set up with any recommendations thank you
1/1/20       #2: Air powered mixer ...
Bill Member
I think I would stick with a 1/2" electric. A decent one is $160. A pneumatic especially a cheap one is not really make for that.
Good Luck
1/1/20       #3: Air powered mixer ...
Chris
That’s what I use.you can regulate speed by dropping air pressure.
Think it’s safer than an electric drill
1/1/20       #4: Air powered mixer ...
perley bowen
I have used a cheap air drill for years. Don't remember the brand but the paddle valve controls the speed.
Perley
1/2/20       #5: Air powered mixer ...
SteveL Member
I use one of the cheap grizzley air drills.
Works fine. They are cheap so you can try it out without worry.
1/2/20       #6: Air powered mixer ...
Tom Gafgen  Member
Website: http://www.TPGCABS.com
Thanks for the replies , will give it a try.
