Milesi WB - HGA13
5/28/20
chris Member
Looking for input regarding spraying Milesi HGA13 - using HNB40 hardener.
Spraying with a CAT-CPR H2O (GRAVITY), most times using 3Mpps.
Really like the HGA19, it flows so nice and light, but have been having trouble with the HGA13.
Any recommendations on tip size and air pressure? Searched through the Milesi website and couldn't find any materials on mixing and spraying.
I like the way the HGA13 looks when i get it right, but it seems I'm always fighting it to flow fast enough for slightly larger pieces.
I'm here in Tampa, FL if you need a picture of the climate.
thanks
5/29/20       #2: Milesi WB - HGA13 ...
DannyB
Are you thinning it at all?
(The TDS that covers mixing and spraying should be available from your distributor)
6/1/20       #4: Milesi WB - HGA13 ...
chris Member
i have been thinning some, then started reading on this site that the thinning should be based on weight, not volume.
luckily one of the other members emailed me the application guide.
6/18/20       #5: Milesi WB - HGA13 ...
Shane
Propylene glycol is your friend...... this will slow it down and let it flow out. Start at 5% reduction with it and do some testing for dry times..
