new spray pump and gun
6/10/20
PJ Member
Getting ready to buy a new spray gun and pump. I have used several different types in my 30 plus years in the cabinet business. What would anyone recommend today if you where buying new? Seems like some that I have used for years are getting built cheaper and cheaper . Not near as good built as they where.
6/10/20       #2: new spray pump and gun ...
pascal stgelais
i spray my clears with a graco merkur es 15:1 with g15. very happy with it but I depend what you really intent to spray. hard to tell
6/10/20       #3: new spray pump and gun ...
chris
how much do you spray and what materials?
been using kremlin pumps and guns for last 20 years
6/10/20       #4: new spray pump and gun ...
PJ Member
I also use kremlin pumps and guns. Happy with the older ones. I spray primer and paints thru one pump and clears thru another.
6/10/20       #5: new spray pump and gun ...
herb johnson
the key to comparing pumps is to look at gpm and the cycles, that will tell how hard they are working to deliver the fluid, most of the pumps are in the 14 to 18-1 range at .04 gpm range. with coatings getting thicker i have been buying the higher pressure ranges even though i don't need the higher pressure yet but the pumps last over 15 years and the wbornes need about 1000 psi. to me, their is a lot of parity between graco, binks, kremlin, wagner and cat, and same goes with pricing but parts pricing their is quite a difference
just my two cents
good luck
herb j
