Acrastrip pump flush
10/13/20
CraigM
For those of you using acrastrip to flush pumps, are you thinning it 2pts water 1pt acrastrip? Do you let it sit overnight in your lines? I have a pail of acrastrip 800 and am thinking of using it to flush a kremlin pump that I run wb through.
Thanks,
Craig
Midnight Finishing
10/13/20       #2: Acrastrip pump flush ...
david zaret Member
i use it, and my mix is ~50/50. i leave it in all the time, sometimes for weeks on end. seems fine. i am not entirely convinced that acrastrip is actually softening any cured waterborne finish, but it's certainly better than water.
10/16/20       #3: Acrastrip pump flush ...
Jonathan Mahnken
ive been using "Extreme Simple Green" and when mixed full strength it actually does soften cured finish. It claims to be easier on internal parts that arent stainless also
10/16/20       #4: Acrastrip pump flush ...
david zaret Member
jonathan - good info, thanks. are you talking about the "aircraft" simple green? and, what dilution are you using? it says that anything stronger than 13:1 could be corrosive to metals, curious what you've found that works. thanks.
10/17/20       #5: Acrastrip pump flush ...
Jonathan Mahnken
Yes the aircraft simple green. To remove old finish I mix slightly less than half and half. it makes a lot of suds so try not to agitate or introduce to much air. it can get kinda foamy in the pump.
