stripping catylised laquer
12/12/20
karl p damour
best way to strip catylised laquer. cherry dining room table
12/16/20       #2: stripping catylised laquer ...
Jim Clark Member
For me I use a rotary sander with 80 to 120
grit. (A rotary car buffer also works real fast).
I then use random orbit to finish sand.
12/16/20       #3: stripping catylised laquer ...
chris
make sure it is solid cherry and not veneer.
12/16/20       #4: stripping catylised laquer ...
Jim Clark Member
Good point, I won't strip veneer that way.
12/25/20       #5: stripping catylised laquer ...
Daniel Shafner Member
Get a five gallon pail of Hoodstrip paste stripper from Hood Finishing Supplies in NJ. It costs approx $130 - maybe $150 - with shipping. After solvent wiping your table with naphtha, and then with 50/50 ammonia & water, score the finish by hand with 120 grit sandpaper, apply the paint remover, and scrape it with a putty knife that has rounded corners, being careful not to gouge the wood.
Repeat as needed.
Clean up with denatured alcohol & water.
12/25/20       #6: stripping catylised laquer ...
masterblaster
After slappin the hood stripper on, place a sheet of plastic over the piece for a while. You'll get stripper action with less stripper. once it dries it stops working so the longer it stays wet the better it works. Also you can use saw dust and a stiff nylon brush(home depot) to remove stripper and finish.
