Kremlin Tip Cleaning
1/4/21
Kevin B
Does anyone have any tips or the cleaning procedure they use for Airmix Kremlin tips after spraying. We spray mostly ICA waterbase. We rinse and poke out the orifice with the Mega micros and blow out with air. Does anyone try to save , or clean out the small tip filters or just toss em, I've not had good luck trying to clean those out. Is anyone using an ultrasonic?
1/4/21       #2: Kremlin Tip Cleaning ...
Bob Niemeyer  Member
Kevin, Have you tried the waterbased cleaner D1057? If not have your supplier get some for you. It is a cleaner based off of the co-solvents in the coatings formulation and works very well. Now if you are running catalyzed products just get them in the cleaner before full cure otherwise you will need to use a liquid methylene chloride based stripper to give them a quick soak and then use the D1057.
1/4/21       #3: Kremlin Tip Cleaning ...
Kevin B
Bob
We have D1058 is it the same? I dont find the it works that great..
1/4/21       #4: Kremlin Tip Cleaning ...
herb johnson
if you don't have an ultrasonic cleaner i would invest in one , i recommend acra strip in a fifty fifty mix with water until then the best way to clean out the tip is this, once you flush the unit out, put the tip back in the gun, turn off the atomizing air , turn the pump pressure up to 85 to 90 psi fluid pressure and rapidly trigger the gun with clean solvent or water or whatever you use and power clean the tip, that will will clean out the tip
good luck
herb j
1/4/21       #5: Kremlin Tip Cleaning ...
Bob Niemeyer  Member
D1057 is a different solvent blend than D1058. D1057 is ok to leave tips/filters soaking in it. Ultrasonics are nice and do a good job also. Are you running catalyzed product?
Are your tips/filters not getting clean or are you looking for something to soak them in?
If you could go into a little more detail on what you would like to do then I can suggest the best product to use.
1/4/21       #6: Kremlin Tip Cleaning ...
duster
I got a small ultrasonic cleaner last year to clean the tips of our various spray equipment. It works great, I wish I'd done it sooner. We also use acra strip mixed 50:50 with water.
1/4/21       #7: Kremlin Tip Cleaning ...
Kevin B
We are using a catalyzed mix, like say primer FA452B after a spray session, I just don't find anything that really cuts through this stuff, water works but you still get small flecks left in a fine mesh. The 1058 is pretty intense odor, but not a deal breaker.
1/6/21       #8: Kremlin Tip Cleaning ...
I am in Canada, just wondering who sells the Acra strip, I asked a few places who I thought might have it and they looked at me funny. Thanks
1/6/21       #9: Kremlin Tip Cleaning ...
duster
Scott - I had no local dealer for acra strip, so I called their office and purchased directly from them. I bought only a gallon, but that's enough for several years of occasionally cleaning spray tips.
