Minimal Clear finish
3/3/21
Hen Bob Member
Good Morning,
The designer on a current job is requesting white oak millwork with a look of no finish on it. What have you guys have been successful with in achieving this? I know this has discussed on here before but I don't recall what product was used. I prefer to use WB if possible
Henry
3/3/21       #2: Minimal Clear finish ...
Jim Clark
I use "flat" conversion varnish, there's even one more flat
than that called "dull" for the brand I use.
3/3/21       #3: Minimal Clear finish ...
Tyler
Sivam natural wood effect.
It literally looks like there is no finish on the piece. I get it sourced from Richellieu.
It's a 2k poly, and quite expensive, but it's a great product.
3/3/21       #4: Minimal Clear finish ...
Bob Niemeyer
Website: http://www.niemeyerproducts.com
All of the european based finish suppliers have the same type of product. 2k urethane performance with the look of bare wood. On oak putting just a very small amount white in the seal coat(drops) will really help the look you want. If you need more info I can hook you up with the right Dist. for ICA products.
3/3/21       #5: Minimal Clear finish ...
Hen Bob Member
Thanks Guys,
Tyler, I think that is what I was looking for.
3/3/21       #6: Minimal Clear finish ...
CraigM
Milesi also makes natural effect 2k's. HGA19 is the waterbased version, LUA118 is the solvent version.
3/4/21       #7: Minimal Clear finish ...
JeffA
Agree with Bob. The white helps to hide the amber in the wood when coated.
3/7/21       #8: Minimal Clear finish ...
Ed
Just had a job in rift white oak . The architect and designer chose Rubio mono-coat.
