Sand through touch up
3/28/21
Nicko Member
What is anyone using for edge sand through touch up on stained wood?
Thanks.......nicko
3/29/21       #3: Sand through touch up ...
Wyatt
We use Mohawk Blendal sticks but I just looked at their website apparently they have a product specifically for this purpose called a sand thru stick. I haven't tried these yet but I'm definitely going to order some right now.
Sand Thru Stick
3/29/21       #4: Sand through touch up ...
Nicko Member
Thank you Wyatt,
I will be ordering.
Nicko
3/31/21       #5: Sand through touch up ...
Blendal Sticks or Fil-Stik's are my go to for burn throughs. Plus I have an assortment of their Pro Mark markers.
4/1/21       #6: Sand through touch up ...
nicko
I wonder what the difference is between the blendal sticks and the sand thru sticks?
nicko
4/27/21       #7: Sand through touch up ...
Daniel Shafner Member
The Blendall color stick is only meant for purposes of coloring. It's based on bees wax, which is very soft and will always be very soft. In too thick an application it can affect intercoat adhesion and it will likely bleed into the topcoat.
The Sand Thru Stick is based on a hard wax which gives it some filling properties.
Both sticks require topcoats. If ypur use of the Sand Thru stick isn't giving you enough color replacement, use the Blendal Stick on top.
Some notes about Blendall Sticks:
*They're extremely sensative to heat. Heat ruins them and they don't recover/heal.
*Apply the Blendall Stick, then smear it with your finger.
*Best results for applying the Blendall Stick are gained by shaping a conical point on one end with a small pencil sharpner.
    • 2Sand
