Black Conversion Varnish
10/21/21
Richard
Website: mellors.biz
Every time we spray black Sherwin Williams CV 20% sheen we get small areas that look like the sheen you get with oil on water, a little separation in the color if that makes sense!
My finisher thinks it's the pigment coming out of suspension as it's drying.
It's causing a lot of reworking and then some doors having extra coats on them.
It only happens with very dark colors.
Any suggestions?
10/21/21       #2: Black Conversion Varnish ...
Mastercabman
I never done this but I know a couple guys that spray a black (or dark color) primer and then top coat with clear
10/21/21       #3: Black Conversion Varnish ...
That's what I do for black. Black primer and then a clear coat. I find clears more durable than pigmented and the MLC Black Clawlock is tinted with carbon black so it's not a dark blue or a dark green. It's a true black.
As for your problem inconsistent spraying is usually the culprit. I assume you are doing a box coat which helps keep you from getting striping.
10/22/21       #4: Black Conversion Varnish ...
Hen Bob Member
We do the same as Leo, usually add some black pigment into clear coats as well
10/22/21       #5: Black Conversion Varnish ...
I stick with just clear. The black dye I would use to tone the clear is a dark dark blue. The black primer is a true black.
10/25/21       #6: Black Conversion Varnish ...
Richard
Thanks, we just picked up some black primer and will try it out.
