More on Spraying CV
3/20/22
howard Member
Website: http://woodcontours.net
Thanks for the answers so far. I am thinking of using Mohawk's CV using a turbine HVLP Apollo cup gun. I am experienced in spray finishing, my question on direction of spray was to find out if it had to be sprayed in only one direction to prevent too much film build. Thanks
3/21/22       #2: More on Spraying CV ...
No.
Spray X & Y directions
You need to know that you can't spray 4 coats, because of thickness. People tend to overblow the CV thickness issue. Don't be scared of it.
It becomes a problem when somebody orange peels or runs their final coat. If it wasn't CV you would just shoot another coat. With CV you will have to sand some of it off, then have another go.
4/30/22       #3: More on Spraying CV ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
Use a wet film thickness gauge and learn how to determine how many wet mils you are applying with each coat. From that info you can calculate your dry film thickness so you don't exceed the magic 4 mil limit to disaster. http://profinisher.blogspot.com/2014/01/film-thickness.html
