surface protection
7/24/22
A. Scott
I spray a lot of lacquer finishes, and since the pandemic I've found myself shipping a lot more of my furniture pieces (whereas before they were mostly selling locally). I've gotten pretty adept at packing and crating, so that itself is not a problem, but I'm often dealing with tight deadlines that don't allow me as much curing time as I'd like (say 4-5 days rather than 8-10), and I've had some issues with packing materials leaving imprints on the finish. I've tried a number of different products with mixed success, and maybe there's no silver bullet out there, but I'm wondering if there's something I haven't tried that might give me a better chance?
7/24/22       #2: surface protection ...
Have you tried something like wax paper as the first layer? Definitely don't use bubble wrap. It will melt into the finish.
7/24/22       #3: surface protection ...
You could bake the finishes to accelerate the curing process.
7/25/22       #4: surface protection ...
Chemmy  Member
Without knowing the brand or type of nitro finish your using, It's a guessing game at best.! The type and number of coats applied, play the biggest role in how long it takes to get thoroughly dried. the factories in Grand Rapids Mi. When using regular nitro wood lacquers, would send the products through a tunnel of high impingement air nozzles that would break the vapor barrier allowing the solvents to escape at a much faster pace than they normally would be able to.! But that would be very costly for a small shop.! Most all normal wood lacquers, that are used for wood coating, are prone to case hardening if dried to quickly, and for factory use
( unless they are specifically formulated for being dried quickly).!
When that is the case, those lacquers are some what inferior to those which are formulated to withstand heat, water, alcohol, and deformation of surfaces, etc.! Also the climate and shop conditions very as to location and temps, all of which have to be considered.! So the bottom line is both yes and no as to whether it can be successfully accomplished.
I would suggest you talk to your coatings supplier.." The coatings chemist" not a sales rep., to find out what they recommend in your case... They should be able to tell you what's best in their case for their finishes.!
7/25/22       #6: surface protection ...
A. Scott
I'm spraying NC lacquer – mostly pre-cat, occasionally post-cat. Moisture levels in the shop are variable, so curing times are not consistent.
Wax paper is a good idea, and might work, though it depends on the stiffness; my pieces have a lot of complex curves, and I'd be concerned about creasing and bunching. But it's worth a try...
thanks!
7/25/22       #7: surface protection ...
Chemmy  Member
Hmmm... I can see where using some kind of barrier on a "cured" surface might work, but rapping a finish with anything that will retard/slow the solvent evaporation (the NC part of your finish down especially), may well cause more damage than your currently getting.!
I would advise using at least high speed window fans on all sides and surfaces, a foot or two away from the objects, once the finish is set to the touch and out of dust and other air born contaminates, this is not as good or as fast as high impingement methods, but a hell of a lot safer than anything that causes retardation of the solvent release.! if you do this, do it in your booth while running your booth fan, to evacuate the fumes.! Or....go ahead and try the wax paper, but I am sure this will not work as suggested or intended.
Good luck either way..
Chemmy
7/25/22       #9: surface protection ...
FM
We have had zero problems with almost any solvent based finish blanket wrapping the finish after a couple days above 65 degrees and then shrink wrapping over the blanket wrap.
7/28/22       #10: surface protection ...
Rick Mosher
Don't know how expensive you would want to go but a UV cured finish is ready to ship right away.
7/28/22       #11: surface protection ...
Chemmy  Member
Hey Rick, sam/chemmy
Glad to see your still around.🙂
Does any coatings company make a UV cure Nitro
Finish? If so what is the initiator their useing.?
Haven't been keeping up with that end of things.!
    • 2Sand
